Stall
GYPSYD
200O Honda Civic EX - 160,000 - straight stick- -well maintained - Had oil change - car holds 3.5 qts. - mechanic used 4 qts + 1 pt. of additive. Left garage, CHECK ENG. light came on, car stalls at every traffic light or when I slow down - returned to garage & they drained some of the oil. Said they adjusted the idleing ( said it was a little low) & disconneced the + Battery cable so the computor would reset. Check Eng. light has not come back on but car still stalls. Before I take it back again and complain ( @#%&$#) , could this problem stem from the over fill of oil? What's the first area that should be checked or replaced. Donation forthcoming.
May 22, 2007 at 5:58 AM
JCDINAZ
Just wanted to see if you ever got this problem fixed. and if so what was the problem. I have a 97 accord, that is doing the same thing, And I am lost with it. If you dont mind filling me in could you just email me back at jcdinaz@netscape.net Thank you
Jason
May 24, 2007 at 6:14 PM
  • 75,988 POSTS
[quote:84f9112731="GypsyD"]200O Honda Civic EX - 160,000 - straight stick- -well maintained - Had oil change - car holds 3.5 qts. - mechanic used 4 qts + 1 pt. of additive. Left garage, CHECK ENG. light came on, car stalls at every traffic light or when I slow down - returned to garage & they drained some of the oil. Said they adjusted the idleing ( said it was a little low) & disconneced the + Battery cable so the computor would reset. Check Eng. light has not come back on but car still stalls. Before I take it back again and complain ( @#%&$#) , could this problem stem from the over fill of oil? What's the first area that should be checked or replaced. Donation forthcoming.[/quote:84f9112731]
To commence firing on this one, get it scanned and give us the OBD2 code/s this one can be a bear to find.
May 24, 2007 at 7:00 PM
