SRS light
BRANDON GP
  • 6 POSTS
I have a 1994 honda civic 1.5 4 door automatic 77,000 miles on it. The SRS light is on on the dash and is staying on all the time. I do not know what it is or what it is for.
Nov 29, 2007 at 12:44 PM
  • 31,937 POSTS
High there,
S.R.S. stands for Supplementary Restraint Systems. This being Air bags and belt pre tensioners. While the SRS light is on the safety systems are in-op. If you get a code read it will give a fault code for what ever has failed, you will need to do this first, before any action is taken.
Mark (mhpautos)
Nov 30, 2007 at 11:28 PM
BRANDON GP
  • 6 POSTS
I want to know how I can get a coad read for this problem.
Dec 4, 2007 at 11:15 AM
  • 31,937 POSTS
Hi there,
Nearly all mechanical work shops should have a universal code reader, it will take about 2 minutes to read, just make a phone call to your mechanic and ask if they have the scanner. I do believe that you will be able to purchase a scanner to suit you car cheaply, and i see that some parts outlets do scan reads as well, as i am in Australia, i don't know who can do this, but you should be able to find out with a few phone calls.
Mark (mhpautos)
Dec 4, 2007 at 12:21 PM
