1998 Honda Civic Belt Squeal at Idle
98EXCIVIC
  • 7 POSTS
98 Honda Civic EX, manual, 106k miles, 1.6L VTEC.
Had all my belts (timing, alternator, power steering and a/c), and water pump replaced @100k miles. Belts were squealing due to wear before changing them. After about 3 weeks they started squealing again, they were perfectly quiet before. I've tightened the power steering belt (it was a bit loose), and it didn't help at all. I've checked the alternator and a/c belts and they are tight and meet maintenance book specifications.
It only squeals at low RPM- when idling at stop sign/light. Once I get going, the noise is gone. Any ideas? My guess is that it HAS to be a belt, but why all of a sudden after 3 weeks?
Jun 18, 2007 at 7:46 PM
BRUCE HUNT
  • 3,754 POSTS
Some belts do stretch, who knows for sure, but the noise is a belt. So.....with the engine OFF, on each belt find the longest section of each one between pulleys. You have two right? At this location, the distance the belt should move is .5 inches in each direction. Total play of not over 1". Adjust to meet that and try the low idle.
Jun 19, 2007 at 1:00 AM
98EXCIVIC
  • 7 POSTS
I've read here on the forums that if the timing belt it too tight it can squeal too- is there a way to check it. Beyond that, if it is tight, can I just deal with the squeal and let it stretch until it's quiet or will it hurt the belt being that tight?
I will go home today and recheck belt deflection and tighten if need be.
Jun 19, 2007 at 1:13 AM
BRUCE HUNT
  • 3,754 POSTS
The timing belt is lugged and should not be making any noise.
Jun 19, 2007 at 4:58 AM
Suggested Repair
With the engine off, check deflection on the longest span of each accessory belt and adjust so each moves about 0.5 inch in either direction, with total play not over 1 inch. Recheck at low idle. The timing belt is toothed and should not cause the squeal.
Conversation Summary
A 1998 Honda Civic began squealing at idle about three weeks after the timing, alternator, power steering, and A/C belts and water pump were replaced. The noise disappears once the car is moving. Tightening the power steering belt and confirming the other accessory belts met spec did not help. The expert said the noise is from a belt and advised checking deflection with the engine off, adjusting to about 0.5 inch each way with no more than 1 inch total play, then testing at idle. The timing belt should not squeal.
