2001 Honda Civic Squealing noise from tranmission
RUSSELLDM
  • 2001 HONDA CIVIC
Noises problem
2001 Honda Civic 4 cyl Two Wheel Drive Automatic
I am getting a squealing noise from the transmission. Occurs only when the stick is in "D", and only in lower gears. Any ideas?
Monday, August 30th, 2010 AT 12:31 AM
  • 31,937 POSTS
Here,
Thank you for the donation,
This sounds like a slippage problem, I would not be driving the carr very far as you may be doing more damage to nit, I would get t inspected by a transmission specialist as they will have all the special tooling required to do a full diagnosis on this, you may get some insight if you do a scan and see if there are any transmission unresolved fault codes, I would start here.
Mark (mhpautos)
Monday, August 30th, 2010 AT 1:33 AM
