2000 Honda Civic Washer Not Spraying
ZACHPEDERSEN
  • 9 POSTS
2000 honda civic, the sprayer doesnt spray im thinking its a pump but i dont know.ive been driving blind for a week without a sprayer ..
(please help me please) 2cars pro rokks!! thnx 8) :D
Jan 9, 2007 at 2:49 PM
BRUCE HUNT
  • 3,754 POSTS
Yes it could be the pump especially if both sides don't spray. First of all ensure that you have fluid. Then I would look for the hose coming out of the resevoir and ensure that the line is free of any blockage. Any time you have a problem like this start at one end and work to the other end. Crap in the system will cause blockage. With the engine off and an assistant try to run the washers. See if the pump runs. check fuses as well.
May 10, 2021 at 4:55 AM
Suggested Repair
Confirm washer fluid is present, then inspect the hose from the reservoir and the rest of the lines for blockage, working from one end of the system to the other. With the engine off and a helper, operate the washers to see if the pump runs, and check the fuses. A failed pump is possible if both sides do not spray.
Conversation Summary
The owner of a 2000 Honda Civic reports that the windshield washer does not spray and suspects the pump. The expert advises confirming fluid, checking the reservoir hose and lines for blockage, verifying that the pump runs with the engine off, and checking the fuses.
