1997 Honda Civic Shifter Stuck
STAHCEE7
I own a 97 Hona Civic Ex auto... The shifter all of a sudden seems to be getting stuck. This just started last night I had to use two hands to move it! Very strange! This morning it was a little hard to move but I could actually move it..It is doing this no matter what gear I am trying to put it in. What causes this problem? Any suggestions?
May 4, 2006 at 3:22 AM
LOSONE
  • 1,616 POSTS
There is a shifter bushing that may be causing the problem. Remove the knob, boot and the plastic junk and see if you can see anything. You may have to remove the shifter. Let me know.
May 4, 2006 at 9:36 AM
STAHCEE7
Actually i did take it apart and got it to work! it was jammed! thank you anyhow
May 4, 2006 at 3:01 PM
LOSONE
  • 1,616 POSTS
Thanks for the feedback. losone
May 5, 2006 at 10:17 AM
Suggested Repair
Inspect the automatic shifter for a jam or worn shifter bushing. Remove the knob, boot, and plastic trim to check the mechanism, free anything jammed, and replace the bushing if worn. The shifter may need to be removed for a full inspection.
Conversation Summary
A 1997 Honda Civic EX automatic shifter suddenly became hard to move in every gear. An expert suggested a worn shifter bushing and advised removing the knob, boot, and plastic trim to inspect, possibly removing the shifter. The owner later reported the mechanism was jammed and worked after being taken apart.
