1988 Honda Civic automatic shifter cable
1988 HONDA CIVIC
HOFFA23
Transmission problem
1988 Honda Civic 4 cyl Front Wheel Drive Automatic
hi. im interested in purchasing a 1988 honda civic. problem is the owner believes the automatic shifter cable is stretched. Would this create a large problem with actually driving the car, would is allow the car to move and would it be expensive to fix?
Feb 23, 2009 at 2:01 AM
KHLOW2008
  • 41,814 POSTS
Hi hoffa23,
Shift cable is listed at $347 and labor time is 1.3 hours.
If the cable is bad, you might have to overshift slightly and wiggle the gearshift to get the correct position. If you are able to get the correct gar position, then there would be no problem whatsoever.
Feb 24, 2009 at 12:29 AM
