1995 Honda Civic Door Replacement Fix
EPICSWELL
How to replace the front passenger car door on a 95 Honda Civic EX 4-Door? Thanks in advance for advice?
Apr 29, 2006 at 3:13 AM
SQM
  • 6,383 POSTS
Replacing the door on your vehicle can be done relatively easily with using simple hand tools.
First you want to disconnect the door check. Then take out the rubber boot that has the wiring harness thru it. Unplug the harness.
Then have some one hold the door as you take off the door hinge pins.
After the pin removal you will be able to remove the door.
https://www.youtube.com/c/2carpros/featured
Sep 16, 2021 at 3:11 PM
Suggested Repair
Disconnect the door check, remove the rubber boot, and unplug the wiring harness. With a helper supporting the door, remove the hinge pins and lift the door off.
Conversation Summary
The owner asked how to replace the front passenger door on a 1995 Honda Civic EX four-door. The expert said it can be done with simple hand tools: disconnect the door check, remove the rubber boot and unplug the harness, have someone hold the door, remove the hinge pins, and then remove the door.
