1998 Honda Civic Ignition Cylinder Stuck
REDI
I have a 1998 Civic EX coupe Auto. Someone broke into my car and broke my ignition. I was able to get a new ignition from junk yard. I am trying to swap the part where the key goes in to the ignition i got in junk yard. I removed the torx screw in the bottom, but the piece still wont come out. Is there a special tool needed or method???? thnks
Feb 14, 2006 at 10:03 AM
FISHERMAN
  • 937 POSTS
it has a lock, and that only disengage turning the ignition key...
I guess you dont have that key..
you have to make a new one
Ask a locksmith to help you with that, and figure it out the expenses, probably its cheaper buying the part brand new
Feb 15, 2006 at 1:04 AM
DAVAGIRL
Hi there. I had that happen with my Civic, too. There are special tools needed to take the old ignition off. There are no grooves on the screws. I ended up taking mine to a mechanic and having him swap the part out for me. (yes, even the ignition that i got at the junkyard). it did have a set of keys with it. So hopefully you have those.
Mar 30, 2006 at 2:49 PM
Suggested Repair
The ignition lock cylinder releases only when the matching key is turned. If that key is unavailable, have a locksmith cut a key or remove the cylinder, or have a mechanic swap the ignition. A new ignition assembly may cost less than locksmith work. Use the keys supplied with the junkyard unit if you have them.
Conversation Summary
The owner of a 1998 Honda Civic EX coupe cannot remove the key cylinder from a junkyard ignition after removing the bottom Torx screw. An expert explained that the lock releases only by turning the ignition key and suggested a locksmith or buying a new part. Another owner said special tools are required and a mechanic completed the swap, noting the junkyard ignition should include keys.
