Radiator reserve tank
RANDOLF
What is the easiest way to flush and clean the radiator reserve tank of a 2001 honda civic DX without actually removing it?
Jun 2, 2007 at 8:00 AM
MIKE H R
  • 3,094 POSTS
pinch the return hose going to the radiator, remove any existing anti freeze. using a light detergent clean out the tank. sometime you can get most of the junk out with just flushing it but for heaverier spots you can use a old toothbrush or a brush with a long handle that fits in the tank easily. once the tank is cleaned flush with clean water to remove any soap. flush it out well. then refill with anti freeze
Jun 3, 2007 at 3:25 AM
