"a/c belt removal"
HERN615
  • 5 POSTS
1992 honda civic dx..102000 mi.--There is an a/c belt that is giving me problems to removing due to a bracket just above the belt in which I think is part of the power steering pump. Iam having a heck of a time removing it. Is there a trick to this operation.
Your help would be greatlly appreciated in this matter.
Thank you! [look for my donation].
Jun 28, 2007 at 9:25 PM
2CARPRO JACK
  • 11,533 POSTS
There should be 2 - 12mm bolts holding on the tensioner for the a/c belt. If you loosen the 14mm lock nut for the tensioner, you can move the wheel up and down to make access to the bolts easier
Jun 29, 2007 at 1:13 AM
