problem with my honda civic lx 98
KIKACHA
i got problem with honda civic.here it is.sometimes i can't start my car.it needs like 6-10 try to start it.but that's not all.when i drive it sometimes the engine turns off and this is big problem because my car creates traffic.i changed fuel pump,air filter,fuel filterk, even main relay but nothing.same problem.what advice can u give me.whati should i replace? which part can cause problems like that?thx in advance
Jul 3, 2007 at 9:51 AM
CYBRID1
[quote:b180cfa496="kikacha"]i got problem with honda civic.here it is.sometimes i can't start my car.it needs like 6-10 try to start it.but that's not all.when i drive it sometimes the engine turns off and this is big problem because my car creates traffic.i changed fuel pump,air filter,fuel filterk, even main relay but nothing.same problem.what advice can u give me.whati should i replace? which part can cause problems like that?thx in advance[/quote:b180cfa496]
Hey i'm Experiencing that Exact Same Problem.
I just posted about it. Randomly the Engine Dies.
I too have a 98 Honda Civic LX 150k Miles. So far I've replaced Fuel Filter, Air Filter, Plugs, Plug Wires, Dist Cap And dist Rotor. Much to my dismay nothing has resolved it. I'm hoping the experts can shine a light on it If you have heard anything or you have found something that resolved it Please let me know. I've Been told it's either ICM=igni cont module, ECU the computer or the distrubuter. I'm leaning towards ICM or ECU because Under normal Circumstances the dist would cause issues then just fail.
Jul 13, 2007 at 9:29 PM
BRUCE HUNT
  • 3,754 POSTS
I can offer a couple of thoughts. First, when the car does its I don't want to run thing, check the wires to see if spark it present to the plugs. Then if it is present, is there gas being supplied to the cylinders. If you have those items, I might suspect the distributor or the crank sensor. The cam sensor is located in the distributor.
Jul 17, 2007 at 3:57 AM
