1994 Honda Civic Overheating
TNRGRL
i have a 1994 honda civic ex, 130,000 miles, 1.6 sohc. after driving it for about 25 min it begins to get hot and about ten min later it will overheat. had a block test done, so replaced head gasket. did pressure test, so replaced upper hose, radiator, thermostat, and did coolant flush. we bled the system, it worked fine for about two weeks then it started overheating again. did not replace these items in any specific order. both fans work (coolant and ac). and no fluid is found leaking. running out of ideas and stuff to replace, can you suggest anything else? it overheats during acceleration and when you come to a stop it goes back down to normal temp. looked at heater core and doesnt seem to be leaking, also checked water pump and it doesnt seem to be leaking. any ideas?? ps temp goes straight up to half way as soon as you start the car.
Jun 6, 2007 at 1:00 PM
BRUCE HUNT
  • 3,754 POSTS
When you pulled the head off, did they check the head to see if it was warped? Another question or point I would like to mention is the instant rise of the needle in the car. That would tend to point out for me that the sensor feeding the guage is not functioning correctly. There is no way the coolant could get that warm so quickly. Another thought is that it may not be the sensor but the guage itself. Determine first of all if the vehicle is getting hot yet and not fooling you with the bad sensor or guage.
Let us know how you make out.
Jun 6, 2007 at 1:45 PM
Suggested Repair
Confirm the engine is actually overheating rather than showing a false reading. Check the coolant temperature sensor and gauge, since the needle rises too quickly to reflect real coolant temperature. Also verify whether the cylinder head was checked for warpage when the head gasket was replaced.
Conversation Summary
A 1994 Honda Civic EX with a 1.6 SOHC engine overheats after about 25 minutes of driving, especially during acceleration, then cools toward normal at a stop. The head gasket, upper hose, radiator, and thermostat were replaced, the system was flushed and bled, and both fans work with no visible leaks, but the problem returned after two weeks. The temperature gauge also jumps to halfway immediately at startup. The expert advised checking the head for warpage and testing the temperature sensor and gauge before replacing more cooling parts.
