1993 Honda Civic Plugs Not Firing
RICKROSS
hi i have a honda civic,93,252000 miles,automatic and it had a leak so i changed the head gasket valves.another problem came about......the two middle spark plugs werent firing so i checked the distributer cap and changed it along with the rotor. the problem is still there.besides the non firing it also had carbon on the plugs and the car back fired as well as shook and the car turns off when i stop completely and the battery light comes on.ive put in new plugs twice.i need help before this car drains my pockets. i wish i had taken my classes already. i know you guys can help me
Jul 15, 2007 at 11:51 AM
BRUCE HUNT
  • 3,754 POSTS
Those plugs should be expected to be carboned up. They are not firing properly. Have you looked to see if there is spark to the wire from the distributor cap? I have not heard you say the wires were replaced. They are very important and fragile pieces of the puzzle.
Jul 17, 2007 at 4:34 AM
Suggested Repair
Check for spark from the distributor cap to each plug wire. Inspect and replace the spark plug wires if they are worn or not delivering spark, since they were not replaced with the cap and rotor.
Conversation Summary
A 1993 Honda Civic with about 252,000 miles developed a no-fire condition on the two middle spark plugs after head gasket and valve work. The owner replaced the distributor cap, rotor, and plugs twice, but the plugs still carboned up, the engine backfired and shook, and it stalled at a complete stop with the battery light on. The expert said carboned plugs are expected when they are not firing and advised checking for spark from the distributor cap to the wires, noting the wires had not been replaced.
