I have a 98 Honda Civic Hatchback with 99000 miles on it. My problem is the car cranks but doesn't start. It only starts when I add starting fluid so l figuerd it was a gas problem. So I check the fuel Pump and I also checked if the fuel rail was building fuel pressure which it was, so l decided to pull out the fuel injectors and cranck the motor at the same time, of course with a help of a friend, and l noticed that the injectors were not injecting fuel. I also switch ecu's in case if the original ecu was not working properly but even with a different ecu the injectors are not working. What could be the problem?
Nov 15, 2007 at 2:44 AM
