1990 Honda Civic Surging Idle Sputter
KLIESTERJ277
1990 honda civic hatchback 1.5 300,000. When pushing down on the throttle i likes to sputter and when it is at a dead stop or at a low RPM the rpm's rise to 3000 and back to idel rpm over and over again. I have checked if i have a vac liek but i didn't see or hear anything. i think it might be a plug. I have tryed cleaning and repluging the plugs. but i don't know what to do next can you help??
Mar 21, 2007 at 1:13 AM
BRUCE HUNT
  • 3,754 POSTS
You might have one or two issues.
The surging is possible due to a factor on this list:
- vacuum leak from a vacuum line
- intake manifold crack
- intake manifold gasket leak
- dirty idle air control valve
- dirty EGR valve
- bad PCV valve
- air in the cooling system
- low coolant in the cooling system
- sticking air flow sensor on the throttle body
There are others but those are the major players.
The sputter could be a plug or a bad wire.
Mar 21, 2007 at 1:29 AM
Suggested Repair
For idle surging, check for vacuum leaks, intake manifold or gasket leaks, a dirty idle air control valve, dirty EGR valve, bad PCV valve, low coolant or air in the cooling system, and a sticking throttle-body airflow sensor. For the sputter under throttle, also inspect the spark plugs and plug wires.
Conversation Summary
A 1990 Honda Civic hatchback with a 1.5 engine sputters when the throttle is pressed and repeatedly surges from idle to about 3000 RPM at a stop or low RPM. The owner found no obvious vacuum leak and cleaned and reinstalled the plugs. The expert listed vacuum, intake, IAC, EGR, PCV, coolant, and throttle-body airflow issues as likely surge causes, and plugs or wires as possible sputter causes.
