2003 Honda Civic Idle Surging
LANGE25
I have a 2003 Honda Civic with 127,000 miles. When the clutch is in or it is in neutral, the engine revs up on its own up to about 3000rpm, then down to 0 and back up. It continues to go up and down until it is put in gear. Can you let me know the problem.
Jul 10, 2007 at 1:38 PM
BRUCE HUNT
  • 3,754 POSTS
The engine is surging. Does it do it cold, warm or anytime? Generally, a vacuum leak or air trapped in the cooling system. I would search for vac line problems and bleed the cooling system. Bleeder should be located at the top radiator hose near the head. There us know how that worked.
Jul 11, 2007 at 3:29 AM
Suggested Repair
Check for vacuum leaks and damaged vacuum lines, and bleed trapped air from the cooling system. The bleeder is at the top radiator hose near the cylinder head.
Conversation Summary
The owner of a 2003 Honda Civic with 127,000 miles reports that the engine revs up and down to about 3000 rpm while the clutch is depressed or the transmission is in neutral, stopping when it is put in gear. The expert identifies idle surging and recommends checking vacuum lines and bleeding air from the cooling system.
