Check engine light
2003 HONDA CIVIC HYBRID
75,000 MILES • 4 CYL • FWD • MANUAL
GARDENINGGAL
The light on the dash that looks like a little engine just came on after filling up with gas. I was told the I have a bad gas cap. Is this correct?
Jun 4, 2010 at 1:23 PM
SATURNTECH9
  • 30,869 POSTS
We need to run the codes this video will show you how.
https://youtu.be/dPOrNy-Y9Ng
and
Jun 4, 2010 at 1:31 PM
DSCHWEI
The engine light came on in 2003 Honda Civic Hybrid. I took it to the dealer, who did some testing, told me it was a dual set oxygen sensors that needed to be replaced. $700. My car is running fine. Is this worth doing?
Mar 1, 2019 at 11:47 AM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
Remember, these are different brands and 1 each.....look for "exact fit"
See this too
https://www.2carpros.com/questions/2001-hyundai-elantra-code-reader-such-one-auto-zone-advanced-diagnose-problem-tha
The stealership is not the only game in town!
In the future....keep this in mind too
See my 6th and 7th answer in this post...may help you with future stuff too!
https://www.2carpros.com/questions/1977-jeep-cj7-front-wheel-wont-into-4-low
The code in the above link also saves with smaller amounts too, just not as much
Sometimes we do what we gotta do.....it seems to be done now,
.....and you are happy?.....that's what matters!
Maybe do a little research next time for a better deal?
Ever thought about a jeep wrangler?
My jeeps make me really happy!
The medic
HONDAD
car will not move in any forward gears, it does move in reverse but makes light grinding noise while in reverse. it makes no noise at all in any forward gears. check engine light is on and codes are p0700 and p1885.. ?? note, i bought the car in this condition.
  • 110,244 POSTS
Both codes deal with transmission issues. You need to have it tested by a trans tech,
HONDAD
yes, i know what the codes mean. when i asked the question i expected a tech to answer it. maybe a member will have some thoughts on this problem ?
HONDAD
well, where r the pros ? and this socalled expert ? what a joke, this site is a waste of time.
AUNTBEV
check engine light is flashing rapidly and car bogs down, but rpm's race to 5000 going 60 mph. Its almost like its in low gear. This car is on its 3rd battery, and runs well other than this. Thank you for your time and thoughts on this matter.
BLAZE45
  • 380 POSTS
If the check engine light is on, take it into a auto parts store. These places will generally tell you what the code the computer is throwing and what is wrong.
Good luck.
2CP-ARCHIVES
  • 4,540 POSTS
My engine light came on and is flashing an IMA code. I understand that this is the motor that runs the battery pack operations of my car. What is the cost to replace this motor?
first, what is the code number??? a code never identifies a bad part, just a failed system.
lets do the diag before jumping to any conclusion.
who told you this part was bad.
