2003 Honda Civic Hybrid clutch or transmission
2003 HONDA CIVIC HYBRID
62,000 MILES • 4 CYL • FWD • MANUAL
HYBRED WOES
with engine running and clutch not engaged i can shift through all gears , nothing happens. would this be a worn clutch or manual trans problem. i smell burning material
Jan 19, 2010 at 2:41 PM
AUTOMD
  • 50 POSTS
I had the same issue with the burning clutch/brake smell. I checked, and the rear hubs were much hotter than the fronts after a drive. I narrowed it down to the e-brake system. I took the rear brakes apart and cleaned everything up.
Feb 22, 2010 at 5:41 PM
HONDA TECH 1818
  • 536 POSTS
If you can shift gears without pressing the clutch pedal the clutch is worn.
May 16, 2010 at 4:58 PM
SCSUPERMAN2000
  • 6 POSTS
[quote:275d4d50ff="hybred woes"]Transmission problem
2003 Honda Civic Hybrid 4 cyl Front Wheel Drive Manual 62000 miles
with engine running and clutch not engaged i can shift through all gears , nothing happens. would this be a worn clutch or manual trans problem. i smell burning material[/quote:275d4d50ff]
they have faulty transmissions they burn the tranny fluid when they go
Jul 26, 2010 at 4:15 PM
