How stop valve clatter during normal acceleration.95 Civic
DANTHEBODYMAN
This is my first time. I made a $5 donation. I own a 95 Civic LX with 107k miles. During normal accelleration I can hear the valves clatter. A friend recommended that I put 1/2 quart of transmission fluid in the oil to clean the area around the valves. Is this a good idea? If not, what is the solution to the problem and what kind of estimate can I expect. Thanks...Dan
Nov 25, 2006 at 2:05 PM
BRUCE HUNT
  • 3,754 POSTS
NO, do not put the tranny fluid in to the car engine. That would really thin the mix and you do not want to do that.
How have you determined that it is valve clatter?
You also need to give me some more information such as how many miles are on the engine and anything that you know leading up to the determination of the valve clatter. Does it use oil, does the coolant sometimes disappear without leaving a puddle anywhere, and is there a loss of power?
Nov 26, 2006 at 2:00 AM
2CARPRO JACK
  • 11,533 POSTS
valve clatter or detonation(pinging)
Nov 27, 2006 at 9:30 AM
