1996 Honda Civic Dies Then Won't Start
SLIMERHONDA
96 Honda EX 120K Manual Trans
I was driving 2 weeks ago and my car jerked and just died. I had it towed to a repair shop and they replaced the distributor and I also had a full tune up to replace the cables and cap. Everything seemed to be okay but when I got off of work today, my car won't start. I had to have it jumped to start it and I figured I probably just left the light on or something but when I got home, I tried turning off the ignition and turning it back on but it won't start again. I don't know if this had anything to do with the part that they put 2 weeks ago (still under warranty) or if this is just a new problem (i.e starter or alternator) ... I'm so confused right now. I would really appreciate all the help ... Thanks a lot!
Jul 30, 2007 at 4:32 PM
  • 31,937 POSTS
Hi there,
I would be checking the servicabality of the battery and terminal clamps also check that the alt is charging 13-14 V would be a good bench mark.
Mark (mhpautos)
Jul 30, 2007 at 5:44 PM
Suggested Repair
Check the battery condition and terminal clamps, and verify that the alternator is charging at about 13-14 volts.
Conversation Summary
The owner of a 1996 Honda Civic EX said the car jerked and died. A shop replaced the distributor and performed a tune-up including ignition cables and the cap. Two weeks later the car would not start without a jump and then would not restart. The expert advised checking the battery and terminal clamps and confirming alternator charging voltage of 13-14 volts.
