1998 Honda Civic Hood Won't Release
Suggested Repair
The headlight cannot be removed with the hood closed. Raise the car on ramps if needed and access the latch from below after removing the underbody shroud, or remove the center of the grille to reach the latch. The latch was seized by rust, so free it with penetrating oil, then clean, lubricate, and reinstall it.
Conversation Summary
A 1998 Honda Civic owner could not open the hood because the release cable had stretched and the latch was corroded. An expert suggested accessing the cable or latch from underneath after removing the front plastic shroud, preferably with the car on ramps and a helper. Removing the headlight was not possible with the hood closed. The owner removed the grille center and the rusted latch, freed it with penetrating oil, then cleaned, lubricated, and reinstalled it.
