Honda Civic Ex 94 87000 ml 1.6L manual shift
2012 HONDA CIVIC
RJIMENEZ19
My car's on a cousin's garage, not getting any direct sun or water, while I perform some repair at home, wasn't started on three days so I went to warm it up on neutral, I started the car, not providing any gas, a few seconds later, no weird noises but the engine trembled a little and then it stopped, happened a few times. I've been said the car should hold at minimal when started on neutral, It's this true? Or is it normal that it stops? Is anything wrong or something I should be looking for? Thanks from your help.
Jul 23, 2007 at 8:57 AM
BRUCE HUNT
  • 3,754 POSTS
The engine should start without touching the gas pedal at all and keep running. It should also drop the higher idle to normal idle itself, again without touching the pedal AND it should not quit.
I suggest you pull out the EFI relay up under the dash on the driver side. They are know culprits. It could be the solder joints are bad or the component is bad.
Jan 2, 2021 at 1:26 AM
