I have a 94 honda civic DX. i was driving pretty low on gas and the car cut out. the power stayed on but the engine did not i had it towed home. couldnt get it started. i need help anyone with ideas please feel free. I have spark , i did a compression check , checked the fuel regulator and filter. Changed the fuel pump because eveyone i know said it was most likely that. checked the injectors and they all spray gas like normal. pulled out all the spark plugs cleaned them put them back in. checked the efi relay. the car will crank but not fire at all . checked all fuses. checked the timing and timing belt. the only thing is the ecu when i go under the glove box and pull out the wire and hook a jumper to it to make my engine light blink with the code the engine light stays on solid and the srs light blinks non stop so theres either no code or something maybe its the whole ecu . so i am lost and my dad who knows more about cars then me is confused as well. any suggestions or ideas would be greatly appreciated. Thank you.
Jul 7, 2007 at 10:04 PM
