honda civic 93 turns off on me
HIPHOP
I have a 93 honda civic with 98,000 miles on it and when i drive the car for at list 10 min. It trys to turn off on me. It happened once it did turn off on me ok i did a tuneup on it i changed the wires plugs air filter oil change oil filter but i didnt change the gas filter and a tranmison oil the told me that on a old car you dont change the trany oil this was around last winter and today it turn off on me then i put it in park then it turns on can you help me please thank you
May 4, 2006 at 7:39 AM
PEPPERMRJ
  • 1,158 POSTS
A year make and model will help find answers. :)
Sounds as if your vehicle is overheating. Is coolant boiling out? Could be anything from low coolant level to a bad rad fan. Have it checked and repaired quickly as overheating can ruin an engine.
Good luck and let us know. :?:
Mar 19, 2006 at 8:45 AM
LOSONE
  • 1,616 POSTS
Not a lot of specific info but it sounds like it is your EFI relay. It controls fuel and spark and is locted high up in the dash above your right knee for a left hand drive car. Good luck
May 4, 2006 at 7:58 AM
