honda civic 1993
MECA389
hello i have a big problem with my honda one day when i turn off the car the next day when i try to start again the car the car dont start. i Change the ignition distribution Fuel Pump Fuel Filter Spark Plug i dont know what is the problem
i think is the time belt but i see the time belt in good condition
Please help
Nov 7, 2006 at 1:03 PM
BRUCE HUNT
  • 3,754 POSTS
Have the codes read from the computer. It could be a sensor. There are the obvious starting items on any internal combustion engine. First, is there spark to the plugs. Second, is there gas to the cylinders. and then is the timing of the spark correct to the delivery of fuel.
Nov 8, 2006 at 2:09 AM
AMER_C
meca389,
If you have a manual transmission car check your cluth pedal ... ckeck your clutch oil. Try to see .. if you can start your car when you depress fully the clutch pedal. Other thing to check is your starter (needs replacement may be) .. when you start you hear clicking.
Nov 29, 2006 at 6:40 AM
