1998 Honda Civic Gas Smell Rough Idle
FONSECAA
I have a 1998 Honda Civic dx automatic 4 cyl with 160000 miles. I drove around all day with no problems. At the end of my day I got in my car to go home and started driving. In about a hundred yards I noticed a gas smell coming from the vents and the car started to lightly shake and buck. Simultaneously the check engine light started flashing continuously. The car feels like it is going to stawl as I slow down and when I am stopped. I have read hundreds of forums tonight and have not found anything exactly the same as my problem. Any information you might be able to provide would be usefull.
Sincerely, Anthony J Fonseca
Feb 1, 2007 at 12:22 PM
2CARPRO JACK
  • 11,533 POSTS
You need to pop the hood and visually inspect the injectors for leaks, sounds like one of them has gone bad on you,inspect the whole fuel system if they look dry. This MUSt be handled ASAP, fuel leaks are very dangerous, we dont want to hear about any car-b-ques!
Feb 1, 2007 at 11:38 PM
Suggested Repair
Immediately inspect the fuel injectors for leaks and check the entire fuel system if they appear dry. Repair any fuel leak before driving further because of the fire risk.
Conversation Summary
The owner of a 1998 Honda Civic DX automatic reported a sudden gas smell from the vents, light shaking and bucking, a continuously flashing check engine light, and near-stalling when slowing or stopped after driving normally all day. The expert advised an immediate visual inspection of the injectors for leaks and of the whole fuel system if the injectors look dry, warning that fuel leaks are dangerous.
