flooded floor
THERESE.LARSEN
I have an 86 Honda Civic with a terrible leak. We have sealed the windshield a few times... we can't figure it out. Now i have about 2 inches of standing water in the front. How do you take the floor plug out? :?:
Jan 11, 2006 at 9:05 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the actual water-entry path located and the soaked interior dried and inspected. Confirm any drain-plug location and access procedure for the vehicle before removing interior parts.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
JELLED21
  • 10 POSTS
to get to the floor plug you should take your seats out and pull up the carpet. You should find it under there somewhere. You could also look underneath your car to find out where it is so you don't have to take out all the carpet.
Jan 30, 2006 at 3:19 AM
Discussion summary
flooded floor
A 1986 Civic had substantial standing water in the front floor area despite repeated windshield sealing. The owner asked about accessing a floor drain plug.
Reported outcome: No leak source, drainage result or completed repair was reported.
The suggested plug location was not confirmed. Draining the floor alone would not establish that the water-entry problem had been repaired.
Read the original discussion
