Door Won't Open
DAVIDONEAL
So Saturday, I get in my car, drive down to wash it, can't get out. It's '98 Civic 4 door.
I had just opened and closed the door about three or four times previoius to leaving the house; no problems. And it just didn't open. I tried from the inside, I tried from the outside. No dice. And because the door is closed, I cannot remove the panel to access the door cable and open it manually. Any suggestions?
Thanks.
~David
Feb 14, 2006 at 3:57 AM
FISHERMAN
  • 937 POSTS
roll downr the window and check if you can see something from the top, i think the link fall off.
try to use a wire from the opening...
Feb 14, 2006 at 6:31 AM
