dash issue
245,000 MILES • 1.7L • 4 CYL • 2WD • MANUAL
MATTW_1999
I have the EX two door model with a vetch motor. The car will start roughly then when it turns over the rpm's, and the temperature gauges do not work. The check engine light is on along with the immobilizer light. My check engine light scan tool will not connect. The car drives but once hitting around 3200 rpm's the car will bog. what could this be?
Aug 15, 2017 at 8:05 AM
STEVE W.
  • 15,414 POSTS
It sounds like a possible bad PCM. The only way to check it would be using a factory level scan tool and see if it can talk to the ECM. Then it would be possible to pull the codes and see what the issue is.
Aug 16, 2017 at 1:29 PM
MATTW_1999
I'll give it a shot thanks
Aug 16, 2017 at 8:57 PM
  • 55,732 POSTS
Please let us know what happens so it will help others.
Cheers, Ken
Aug 17, 2017 at 8:52 AM
