Clicking noise on turns
DANGERX
I have a 1994 Honda Civic and everytime I turn the wheel all the way to the left or to the right , I hear a clicking noise. I'm told it could be the CV joint; What should I do? how long can I go with the car like this before it breaks down? and how much would it cost to fix?
Thanks
Apr 28, 2007 at 7:51 AM
SERVICE WRITER
  • 9,123 POSTS
Very well could be the cv joint going bad. You should stick your nose under the car and take a look for a torn boot (as indicated by arrows).
https://images.2carpros.com/forum/automotive_pictures/30961_boot_1.jpg
There isn't much time left on it if it's clicking. It may get more expensive if you wait any longer as you may get charged for a damaged core in addition to replacement. Your best bet is a remanufactured axle. When it breaks because you waited too long, also anticipate a tow charge and inconvenience. You should be able to get a remanfuctured one installed for about $225-275.
Apr 28, 2007 at 9:08 AM
