Car stalling
EKHATCH8877
Hey I have a 1996 Honda Civic hatchback. 150,000 miles manual transmission. 1.5 engine. the car starts up fine and drives perfect. When i am driving on the freeway and have reached speeds up to maybe 65 and i go into neutral to slow down the car sometimes stalls. When i am driving local this doesnt happen often. My car does not have a RPM gauge but it seems to idle just fine. My friend had the same car model and said it might be the throttle body? My old car had a problem with idle and my friend fixed it by making something tighter, but he says thats not this cars problem. Please help thanks!
May 9, 2007 at 5:56 AM
BRUCE HUNT
  • 3,754 POSTS
When you friend mentions the throttle body he is basically referencing several sensors that could be causing the problem. MAF Mass Air Flow is a possible thing to look at. Any Check Engine Light come on?
May 9, 2007 at 9:30 AM
EKHATCH8877
Yes the check engine light is on! i did not know what it meant! what can i do to fix this problem? THANKS!
May 9, 2007 at 11:39 AM
EKHATCH8877
Please help!!!!!!!!!!!!!!!!
May 10, 2007 at 11:25 AM
  • 75,988 POSTS
[quote:cd0151e207="ekhatch8877"]Please help!!!!!!!!!!!!!!!![/quote:cd0151e207]
You need to have the code/s pull in order for us to get a starting point to help you.
May 10, 2007 at 11:52 AM
