1993 Honda Civic Reverse Brake Squeal
RUBYC
  • 6 POSTS
Honda civic 1993 137,000 miles. My brakes squeal only when I'm in reverse. It's been like this a while and getting worse. could this be something other than brake pads? Hope someone can help!
Apr 20, 2006 at 5:17 PM
LOSONE
  • 1,616 POSTS
Front or rear squeal? It sounds like the wear indicator are rubbing which measn you need front pads.
Apr 21, 2006 at 5:27 AM
RUBYC
  • 6 POSTS
it sounds like it's coming from the rear right side, when I'm backing up. It could be both sides, but it's definitely rear.
Apr 22, 2006 at 4:54 PM
LOSONE
  • 1,616 POSTS
It sounds like you need to replece the rear brakes.
Apr 22, 2006 at 8:31 PM
Suggested Repair
Replace the rear brakes. The reverse-only squeal reported from the rear is consistent with worn rear brake shoes or pads.
Conversation Summary
The owner of a 1993 Honda Civic with 137,000 miles reports brakes that squeal only in reverse and are getting worse, asking whether the cause could be something other than pads. After the owner located the noise at the rear, especially the right side, the expert recommended replacing the rear brakes.
