Honda Civic Click No-Start
HONDA94EX
I own a Honda Civic Ex 2 door . I bought the car 3 and a half months ago . The car has been running great until a 1month ago. I accidently left my lights on. Ever since that day about once a week when i try to turn on my car it makes a click and doent turn on. i recharged my battery many times but the dame problem occurs[/b]
Jan 8, 2007 at 7:29 AM
BRUCE HUNT
  • 3,754 POSTS
One simple question. When it did not start did you jump it and did anyone possibly hook up the cables wrong? Here is a very simple but basic and must place to start. Get a battery connection cleaner. Use the internal brush on the battery terminals and external brush on the cable connections. Make sure the connections are in good shape and don't hesitate to replace the cable or cut the end and replace the connection. This is so basic but one that gets overlooked so often. Don't just assume it looks okay.
Jan 8, 2007 at 7:38 AM
Suggested Repair
Clean the battery terminals and cable ends thoroughly with a battery connection cleaner, and replace worn cables or terminal ends if the connections are damaged. Also confirm that any jump-start cables were not connected backward.
Conversation Summary
The owner of a Honda Civic EX says the car began clicking and failing to start about once a week after the lights were left on and the battery was drained. Recharging the battery has not stopped the problem. The expert asks whether jump cables may have been connected incorrectly and recommends thoroughly cleaning the battery terminals and cable connections, replacing the cable or terminal end if needed.
