1997 Honda Civic Alternator Belt Squeak
CHANDARITH
I drive a 1997 Honda Civic Dx with 135,000. During when I'm driving, I hear a squeaking sound from my alternater/belt when I step on the pedal. At a certain speed it stops squeaking. It seems to squeak or make noise at low end speeds. I've check my alternator belt and its not loose at all. Whats seems to be the problem? How can I fix this?
Oct 16, 2006 at 9:02 AM
BRUCE HUNT
  • 3,754 POSTS
Check again on the belt. That belt should be pretty tight. Now a word of caution to not overtighten it as it can do other damage. Two things to look at. First, ensure that it is aligned right and running on the pulleys correctly and fully and not off just a little bit. Secondly, inspect the belt itself to note if it is cracked and dried out. This can cause slippage and noise.
Oct 17, 2006 at 1:45 AM
CORLEY45
also check pulley to see if it has become glaze. belt will slip if it has
Mar 17, 2007 at 6:19 PM
BRUCE HUNT
  • 3,754 POSTS
Thanks Corley, you are right!
Mar 19, 2007 at 6:57 AM
Suggested Repair
Recheck alternator belt tension so it is tight but not overtightened. Confirm the belt runs fully aligned on the pulleys, inspect it for cracks or dryness, and check the pulleys for glazing that can cause slip and squealing.
Conversation Summary
The owner of a 1997 Honda Civic reports a squeak from the alternator or belt at low speeds when accelerating that stops at higher speed, and says the belt is not loose. Experts recommend verifying proper tension without overtightening, checking pulley alignment, inspecting the belt for cracks and dryness, and checking the pulleys for glaze that can cause slippage.
