1995 Honda Civic AC Idle Stall
GASSAVER
  • 5 POSTS
I own a 1995 Honda civic HB I replaced the engine a year or so ago with a D15b. Before I swaped the engine I never had this problem with the AC since then I have. None of the lines were ever disconnected when swapping engine.
The problem
At idle I can run my AC with now problems, moving, the AC runs fine. It is just when I have to seat in stop and go traffic and am moving a inch and having to brake allowing the RPMs to drop or when I'm going to a stop. and have to down shift the RPMs will drop below an unacceptable RPM level and the engine will cut off. Because of the load of the AC. Any help would be great.
Jul 30, 2007 at 10:59 AM
BRUCE HUNT
  • 3,754 POSTS
First of all I would pull off the IAC valve and clean it. Then if that doesn't do it, I would bump up the bottom end idle on the set screw at the throttle body.
Jul 31, 2007 at 1:48 AM
GARGI45
  • 7 POSTS
[quote:66c58aaf35="Gassaver"]I own a 1995 Honda civic HB I replaced the engine a year or so ago with a D15b. Before I swaped the engine I never had this problem with the AC since then I have. None of the lines were ever disconnected when swapping engine.
The problem
At idle I can run my AC with now problems, moving, the AC runs fine. It is just when I have to seat in stop and go traffic and am moving a inch and having to brake allowing the RPMs to drop or when I'm going to a stop. and have to down shift the RPMs will drop below an unacceptable RPM level and the engine will cut off. Because of the load of the AC. Any help would be great.[/quote:66c58aaf35]
i seem to have the same problem if you were able to fix it please tellme i'm in miami and is way too hot.
tanks
Aug 1, 2007 at 2:48 PM
Suggested Repair
Clean the IAC valve. If the stall continues, raise the base idle using the set screw on the throttle body.
Conversation Summary
The owner of a 1995 Honda Civic with a D15B engine swap says the engine stalls when RPM drops under AC load in stop-and-go traffic, although the AC works at idle and while moving. An expert recommends cleaning the IAC valve and, if needed, raising the base idle at the throttle-body set screw. Another user reports the same problem, but no confirmed repair is given.
