1999 Honda Civic Engine Cuts Off
KRONIC1
I own a '99 civic, front wheel drive automatic,currently 70000km, and I am getting a very strange problem, when I start up the car it works fine most of the times, and then sometimes it cuts off and I notice the fuel guage goes to empty (the gas tank is full) I will try to start it up but it will not start the fuel guage will remain on empty, sometimes if I leave it alone for an hour it will start and the fuel guage will go back to full. Then again sometimes it will not start for days. The fuel guage is the only thing that I notice on the instrument panel that is not working at the time this problem presents itself. I took it to my mechanic who works at Honda, and he says that everything is mechanically fine, so now I am evn more confused as to what to do.
Jul 12, 2007 at 11:18 AM
BRUCE HUNT
  • 3,754 POSTS
You need to start at the basics and when the car does not start, determine whether it is gas or electrical that is causing the problem. Check for spark at the plugs and fuel to the cylinders.
Jul 17, 2007 at 3:26 AM
Suggested Repair
When the Civic will not start, determine whether the cause is fuel or electrical. Check for spark at the plugs and fuel delivery to the cylinders.
Conversation Summary
The owner of a 1999 Honda Civic reports intermittent stalling and no-start, with the fuel gauge dropping to empty even though the tank is full. A Honda mechanic found no mechanical fault. The expert advises checking spark and fuel delivery during a no-start to isolate an electrical versus fuel problem.
