1997 Honda Civic Loose Shifter in Gear
CIVICLUV
I BOUGHT A 97 HONDA CIVIC EX 2 DOOR MANUEL. WHAT I DIDNT KNOW WAS THAT THE PREVIOUS OWNER SWAPPED THE ENGINE WITH A 95 D16Z6. THE MAIN PROBLEM... CUS THERE ARE A FEW... IS THAT WHEN YOU PUT THE SHIFTER IN GEAR, YOU CAN MOVE IT AROUND LIKE ITS STILL IN NUETRAL. I DONT KNOW IF THE TRANSMISSION WAS SWAPPED ALONG WITH THE ENGINE ALSO. ANY IDEAS OF HOW TO GO ABOUT GETTING THIS FIXED WITHOUT BREAKIN MY BANK? THANX.
Mar 21, 2006 at 3:58 AM
BRUCE HUNT
  • 3,754 POSTS
Got an old honda civic that has a similar problem. The car has the feel that it is always in neutral but will actually go into gear and work fine. Same? Knowing the shifting it will go through the gears fine. I at first made a box to guide the shift lever but I found out later that the plastic around the shift linkage was worn. Check the shifter linkage.
Mar 25, 2006 at 3:44 PM
Suggested Repair
Check the shifter linkage, especially worn plastic around the linkage or bushings. A similar Civic felt like it was always in neutral because that plastic was worn.
Conversation Summary
The owner of a 1997 Honda Civic EX manual with a swapped 1995 D16Z6 engine says the shifter can still be moved around as if it is in neutral after it is placed in gear, and is unsure whether the transmission was also swapped. The expert describes a similar Civic that felt neutral but still shifted and drove, and recommends checking the shifter linkage for worn plastic.
