96 honda civic dx speed sensor
ROLLNDUBZ22
I have a 96 honda civic and i was driving and the check engine light came on and my speedometer starting going crazy. i used a scan tool and it said speed sensor, so i replaced it cleared the code and the code did not return but i still have my problem also my lights are flickering. Is it a bad new sensor or cluster or alt. I am lost
Mar 14, 2006 at 1:37 PM
FISHERMAN
  • 937 POSTS
make sure that the new sensor its exactly the same as the bad sensor...and also be sure that has been adjusted or installed properly..
Mar 14, 2006 at 1:59 PM
ROLLNDUBZ22
It is the same and went in the same way the old one came out. So I dont know
Mar 14, 2006 at 10:13 PM
SULLY021
RollnDUBZ22- i have the same symptoms in my 1996 honda civic lx. i am stuck... the speedo and the flickering came on practically on my test drive after doing my timing belt and water pump... i assumed it was something i did, or possibly caused (bad ground, pulled wire from connector). Maybe a component coincidentally went bad when i was done working on the car. Where you able to fix your car? Please respond asap, thanks.
Jun 26, 2006 at 6:06 PM
