91 Honda Civic overheated today (almost)
HJOHNSON
  • 1991 HONDA CIVIC
I have a '91 Honda Civic, about 160K miles. Runs like a champ! Today ((an unusually warm day in SF, approx 70 degrees and sunny)) I was driving back from Oakland, (approx 20 mi drive) got stuck in traffic, and my temp. Gague rose up to "H" while idling. After we started moving a little, it went back down to normal. All was fine until I got a few miles from home and started up a long hill. Then it went back up to "H". Turning the heater on helped a little. Then as I got about 6 blocks from home (also severly uphill), it went back up to H. I made it home w/ temp still at H, but it never totally overheated. After a few hours, I started the car and let it idle for a little bit and all seems okay. I did notice at that point a little bit of green fluid had leaked out the bottom. Help! Any ideas on what the problem might be? And if this is an expensive repair?
Is it okay to drive short, hilly distances in cooler weather for a couple of days?
Any help would be so appreciated.
Saturday, February 17th, 2007 AT 6:28 PM
2CARPRO JACK
  • 11,533 POSTS
Cant condone driving it until its fixed, that is entirely your call. Need to find the source of the leak first, cooling system relies on pressure, if the presure isnt right the car will run hot. Does the cooling fan come on?
Sunday, February 18th, 2007 AT 7:39 AM
HJOHNSON
Thank you for the response. The cooling fan doesn't seem to come on. Don't know if this is related or not, but about a week or so ago I noticed that the heat/AC doesn't come on at the lowest level anymore (#1). You have to turn it up to #2 - 4 for that fan to come on and even then doesn't seem to heat as well as it should. (Haven't used the AC; don't really need it)
I drove it for approx a mile today, and nothing bad happened, and I didn't notice any additional fluid leaks from underneath the car. Though I know there's something that needs tended to. Thanks again for any advice.
Hj
Sunday, February 18th, 2007 AT 8:46 PM
