2008 Honda Civic Oil life indicator
2008 HONDA CIVIC
BOLDBAATAR
2008 Honda Civic 4 cyl Two Wheel Drive Automatic
I just changed my car oil and filter. But I don't know how to reset oil life indicator to100%. So please give me the instruction how to do it. Thanks
Nov 24, 2008 at 12:05 AM
KHLOW2008
  • 41,814 POSTS
Hi boldbaatar,
Resetting the Maintenance Information Display
NOTE:
The vehicle must be stopped to reset the display.
If a required service is done and the display is not reset, or if the maintenance display is reset without doing the service, the system will not show the proper maintenance timing. This can lead to serious mechanical problems because there will be no accurate record of when the required maintenance is needed.
1. Turn the ignition switch to the ON (II) position.
2. Press the SEL/RESET button repeatedly until the engine oil life indicator is displayed.
3. Press and release and hold the SEL/RESET button for about 10 seconds. The engine oil life indicator and the maintenance item code(s) will blink.
NOTE: If you are resetting the display when the engine oil life is more than 15%, make sure any maintenance item(s) requiring service are done before resetting the display.
4. Press and hold the SEL/RESET button for another 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to "100."
Nov 24, 2008 at 7:09 AM
