It's hard to determine the relationship between your car & the "couple hour gap". Check your motor & Trans. Mounts. A medium prybar can assist to pry on them & check for broken or loose mounts. The rubber inside of these mounts are the part to focus on looking for cracks & dryrott, but also make sure the bracketts are o.K. Too.
Check the A.T.F., Make sure the fluid level & "red color" are o.K.. Hopefully elliminating a trans. Problem. Never hurts to check every component possible though, If it's a moving part, check it out while your in the neiborhood. Good Luck ! Let us know how ya make out.
SPONSORED LINKS
Tuesday, June 2nd, 2009 AT 12:16 AM
