2007 Honda Civic spark plugs
51,000 MILES • 4 CYL • 2WD • AUTOMATIC
TINATIME78
I am at 51k miles on my civic, mostly highway miles, and I don't know when I should change the spark plugs. This is not something I would do myself, so I would like to know if it is something costly or relatively inexpensive? A few weeks ago when I turned the key in the ignition, there was a slow response. The engine turned over, but it took a while to catch. It seemed fine after that. But then it happened a couple of more times. I don't know what kind of problem this is, but I do want to take care of it before it turns into a bigger issue! Please help!!
Mar 5, 2010 at 2:45 PM
ALEXBINBINA
good thing to start at the plugs. make sure you get the ngk iridium plugs. the thing wont run right on any thing els[quote:71fb2cb8e0="tinatime78"]Electrical problem
2007 Honda Civic 4 cyl Two Wheel Drive Automatic 51,000 miles
I am at 51k miles on my civic, mostly highway miles, and I don't know when I should change the spark plugs. This is not something I would do myself, so I would like to know if it is something costly or relatively inexpensive? A few weeks ago when I turned the key in the ignition, there was a slow response. The engine turned over, but it took a while to catch. It seemed fine after that. But then it happened a couple of more times. I don't know what kind of problem this is, but I do want to take care of it before it turns into a bigger issue! Please help!![/quote:71fb2cb8e0]
Mar 5, 2010 at 3:45 PM
