2006 Honda Civic Whining noise when cold
41,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEBOY
I have a 2 door 2006 civic. When we go to start the car.
We get a loud whing sound when you excelerate.
It lasts till car warms up. Then goes away.Could this be aworn belt?
Oct 17, 2010 at 2:41 AM
F4I_GUY
  • 3,302 POSTS
Yes it could be a worn belt, it could also be that you are a tad low on power steering fluid.
Either way, check your belt, pullies and fluid levels.
Oct 17, 2010 at 4:49 AM
LEBOY
The whining of the engine while acceleratoring would be the power steering fuild? The belts sound logical.
Oct 17, 2010 at 8:27 AM
KHLOW2008
  • 41,812 POSTS
Low power steering fluid would result in the power steering pump whining when cold.
A/C compressor clutch bearing would also whine at cold due to higher rpm and level would drop after warming up.
Oct 17, 2010 at 11:57 PM
