2006 Honda Civic Starting
14,000 MILES • 4 CYL • 2WD • MANUAL
GONEGOLFING18
I have a honda civic si Tons of aftermarket upgrades.
14000 miles
The only problem is i cant get it to start. every thing will turn on. it will even turn over. but cant get it to run. i believe its an electrical problem.
What could it be?
Mar 30, 2010 at 9:09 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 30, 2010 at 10:25 AM
