2006 Honda Civic Reinstalling Axle
30,000 MILES • 4 CYL • FWD • AUTOMATIC
RCCAZORLA
I was replacing the front brakes on the driver side of my civic. I removed the axle nut because I thought I needed to in order to remove the brake rotor. I used a puller and ended up pushing the axle out of the hub. Is there a way to get the axle back into the hub?
Mar 23, 2009 at 3:54 PM
ZACKMAN
  • 4,202 POSTS
It will be an easier job if you remove the ball joint from the steering knuckle. Re-insert the outboard shaft back into the wheel hub
https://images.2carpros.com/forum/automotive_pictures/55316_06civicaxle_1.png
Attach the ball joint back in, and tighten the nut and insert the cotter pin. Tighten the axle nut to 134 ft/lbs.
Mar 23, 2009 at 5:54 PM
