2005 Honda Civic Temperature Gauge
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
SNMRAM35
Hello: I just got my radiator replace about a week ago. The temperature sensor was also replace. All fluid were change. But now the Temperature gauge is going crazy. When am driving through freeway or highways the gauge shows that its fine, but when I start slowing down or actually stop. Thats when the needle goes up to the Red (H) and its telling me its overheating. I pull over and the radiator is fine am not overheating. Then once I start going and don't stop the needle goes back down. What do you think it is? HELP!
Sep 1, 2010 at 6:19 PM
F4I_GUY
  • 3,302 POSTS
You have a cooling system problem.
Either:
-the coolant level is low or not bled properly
-failed thermostat
-failed water pump
-headgasket issue.
Sep 2, 2010 at 11:02 AM
SNMRAM35
Thank you for responding so fast. My husband is going to go back to the mechanic and we will keep these idea on mind. Making sure they verify this suggestions. Thank you again!
Sep 2, 2010 at 5:01 PM
