2005 Honda Civic roaring noise
39,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARILYN56
my question is after i am driving for a little while or especially if i am stopped and idling for a few minutes i hear a roaring noise from the front end of the car.
almost sounds like when the power steering was going out on an old car i had, but this noise continues if i am driving straight or turnning.
thank you in advance for any help on this
Sep 18, 2009 at 12:14 AM
KHLOW2008
  • 41,812 POSTS
Hi Marilyn56,
Noise problems are difficult to analyse online unless you can give a clear description of it happening under what conditions and emitted from where.
If the noise occurs intermittently and while idling as described, I would suspect the cooling fans to be the cause.
Turn the AC on and if noise comes on, check the fan, the motor could be failing.
Sep 18, 2009 at 5:08 AM
