2005 Honda Civic No power
2005 HONDA CIVIC
BIGFREAKYDADDY
Engine Performance problem
2005 Honda Civic 4 cyl Front Wheel Drive Automatic
Replaced blown engine with exact match. Car now overheats and only reaches 4000 rpms. removed thermostat and car still overheats?
May 13, 2010 at 12:51 PM
Check the radiator if its clogged and water pump if its pumping coolant thruout the engine-if okay try bleeding it could be airlock if it continues get it block and pressure tested.
May 13, 2010 at 1:40 PM
