2005 Honda Civic No Fuel
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
24LANDON
I had my head gasket changed on friday. I drove my car until monday. drove great. Monday after noon i started it and it went dead. after that it would not stay running after you started it. Changed only the fuel pump put did not fix the problem. Oh also chacked one fus it was ok. Can you help?????
Jul 21, 2010 at 7:33 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs though its new if okay-clean and test the idle air control valve and the throttle positon sensor
Jul 21, 2010 at 9:26 AM
24LANDON
[quote:84731a6449="rasmataz"]Check the fuel pressure if its within specs though its new if okay-clean and test the idle air control valve and the throttle positon sensor[/quote:84731a6449]
Ok, we checked both of these parts and they seem to be working. whats my next step? Can there be any problems we created when we changed the head qaskets? The car ran great for 4 days after the gaskets where changed. thanks
Jul 26, 2010 at 3:30 AM
  • 75,988 POSTS
Is it cranking over and refuses to start or just won't crank at all/nothing??
Jul 26, 2010 at 7:41 AM
24LANDON
The car starts but goes dead right after it starts
[quote:f751ff1f85="rasmataz"]Is it cranking over and refuses to start or just won't crank at all/nothing??[/quote:f751ff1f85]
Jul 26, 2010 at 8:11 AM
  • 75,988 POSTS
What was the fuel pressure reading when you checked it? If okay -test the main relay
Jul 26, 2010 at 8:21 AM
